BMR Front Sway Bar Install Question?
Installed a BMR front sway bar today with great fitment. Made sure it was lined up right and installed the right way which it is. My question is when I installed my endlinks, there isn't enough room to screw on the top nut. I double checked myself at least 10 times to make sure I had the bushings and washers placed correctly and left the bracket loose until the endlinks were installed. With everything together and flush, the long screw that runs through the bushings comes out flush with the top washer. No room for a nut on either side of the car. What do I need to try?
Mike
Mike
