???BMR K-member & Solid Motor Mounts???
Old 05-12-2004, 07:47 PM
ssmr0501's Avatar
Default ???BMR K-member & Solid Motor Mounts???
I am switching to a tubular k-member and I had already talk to frank at bmr suspension and he said that the spohn solid motor mounts will not work with his k-member. What I am asking is if anyone knows which k-member will work with them or if you modified your own to work with solid mounts.
Old 05-12-2004, 09:41 PM
felton316's Avatar
You need to get the K-member that doesn't include the fabricated motor mount pedastals. You want the one that requires you to re-use the stock ones, but instead of using the stock ones, swap the solids in its place.
Quick Reply: ???BMR K-member & Solid Motor Mounts???
