2002 WS6 Suspension Questions.
I recently bought a WS6 that was previously lowered. It does have lowering springs, the stock springs were not cut. I have the stock springs, and the new ones are red. The shocks were not replaced, and I am hitting the tires from time to time. What would be some options on shocks?
Next: what can be done about the suspension noise? Every WS6 I have driven has a suspension squeak. Is there something that can be done without buying all new struts. This is not my DD, and I only drive it on nice days. The car only has 40k on it.
Here is the car for reference:
First, we have shocks on all four corners, no struts.
Next, while getting new shocks will drastically improve ride quality, handling and overall feel of the car (even brand new off the show room floor the orange/black decarbon shocks you have are total garbage) it likely wont fix any rubbing issues you have with the tires in the rear. You will need to either lengthen the rear bumpstops with a spacer, or roll the fenders.
As for the squeak noise thats likely a bushing. Check the rear LCA bushings, front control arm bushings and front swaybar D bushings.
Location: Illinois, as close to "Normal" as I can get...
Hey Bill, welcome to LS1Tech!
I thought that the car looked familiar from the NastyZ site
Like JD AMG said the stock shocks suck and suck even worse when the car is lowered. First try to figure out what is rubbing and go from there.
I will check the bump stops, and replace as needed. I will also get some half way decent shocks and put them on the car.
Hey Harbones, just trying to get this thing where it don't hit the tires on a bump. It will get there..
Great looking car.
