seized push pin!
seized push pin!
Guys and gals, I have a seized push pin in my brake caliper bracket, and I cant get the ornery bastard out for anything! Anybody know the best way to get it out without breaking everything? I've already been trying to just buy a used one with good push pins on the sales forums, but haven't found anything yet. So I'm going to try to fix this one while I wait for something to pop up. Any help would be awesome, thanks in advance!
For some reason I'm having a hard time picturing what you're talking about, but at work when things get really stuck like that, we might take a rivet gun and hit it with a straight or tapered rivet set. You might not be set up with air tools, though. Just a though.
I went through this the last time I had my brakes done, it was wearing the pad uneven and warping the front rotor. But I had a mechanic do them (since the rotors needed turning), from what I remember he put the caliper bracket in a bench vise and started trying different tricks on pulling it out, sorry I couldn't be more help but it was months ago. check youtube
When I had that happen on my Trailblazer (same basic design) I clamped down on the pin with a bench vise and was able to wrench the bracket around enough to get it to come free after a couple minutes. Then I cleaned the bore out with the proper size drill bit, sprayed it out to clear the bore of any remaining gunk, and reassembled everything with new boots, grease, etc.
If it is really bad it might be worth just getting a new bracket. I don't think they cost too terribly much.
