Camber Issue
Camber Issue
I had my car aligned at Firestone and they said my adjustments were maxed out. (My car was lowered when I bought it.) Left front camber is at -0.3 which im fine with, but the right front is at -1.0. I wanna get this fixed so my tires will wear evenly. My question is will this kit fix my problem?
http://www.summitracing.com/parts/po...0017/overview/
Thanks!
Thanks!
LS1Tech Premium Sponsor
No, that setup will not affect your camber at all. Steering components only affect toe angle. First off, I am hoping that the shop knows how camber is adjusted on an f-body. There seems to be an alarming number of shops that think it is not possible. If they do know how to adjust it, and have attempted to do so, look at your control arm bushings and make sure they are not worn out and collapsed. If all looks well, look at the position of the lower control arm bolts. If they are "maxed out" as they claim, the lower control arm bolt will be pulled as far to the outer edge of the slot. If not, then you still have adjustment left. If you aren't sure what to look for, post a picture of the lower control arm mounting area and I can tell you what is going on
BMR put together a thread in the past that had a list of competant shops that can actually set your alignment to what you prefer. Hopefully there is one in your neck of the woods on that list. I provided one that is local to my area in MA.
Pictures of the adjustment bolts on both of your lower a-arms, so we can see their position, would be helpful. However, if the bolts are already as far INWARD as possible, and you want more positive camber, you need to break out your Dremel tool, and extend the length of the slots about 1/4".
