Coil over advan/disadvantage
What r the differences,, im needing some new shocks,, I already have Eibach springs,, why would I want to go with coil over and will some work with my present springs. Please help,,
Of which there are a few to choose from now and they even have kits to convert the rear to an adjustable coil over. The benefits is being able to fine tune your stance and choose your spring rate (when buying), the down side is being stuck with whatever shock the kit was designed with and not being able to run Koni's or your preferred brand of shocks or any of the typical lowering springs as special springs are needed that work with the coil-over system and the cost tends to be fairly high.
