PST Sway bars- anyone?
LS1TECH Sponsor
Not big enough front, too big a rear in general IMO. I run 1-3/8" front, 7/8" rear (sometimes adjustable).
Your stock front bar was 1-1/4" to start with, and the rear bar @ 1" is a bit too much for the larger front bars, let alone for your smaller one. The rear is much lighter than the front and has no camber loss to roll, you only want/need it to be only as stiff as you need for good balance. Anything else is just taking rear grip away.
In fact if you stay with that front bar, I'd suggest you put a stock 19mm rear bar on it instead (even if your car is a '93 1LE which had a 21mm rear bar).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
I think I'll switch to the same size as your up front and a non-adj rear S-bar.
Now there is an urgency with this project, I removed the rear bar last night to inspect it and sure enough its bent. Sam, I'll want to purchase a new set asap and am considering your hollow bars. I do have a few questions first and looking forward to working with you.
