vibration when full throttle 9in 4l80e
Ok I have a 02 with 9 inch my torque arm is a bmr adjustable. That mounts to the adjustable bmr trans cross member and I am running a 4l80e not sure what the adjustments are suppose to he with the drive angle .. but when it had the 4l60 it didn't vibrate now with the 4l80 I have a vibration at wot . My drive shaft is a mark williams chromoly balanced. If any one can tell me there fix that would be great ..
First thing's first! CHECK PINION ANGLE!
Angle of Driveshaft added to Angle of Pinion. Should be -2.5 with poly bushings. -1 to -2 on solid joints. -3 to -4 on stock bushings.
