Lower control arm help!!!
I was in the process of replacing lower control arm bushings when I when to install the Lower ball joint and it didn't go in straight, I ended up with to much pressure on the a arm and now its mushroomed one side so the ball join won't go all the way in. Now I would rather replace the a arms becuase those bushings and ball joints suck to replace . But I don't want poly joints! I would rather just buy oem control arms but parts direct.com said they are discontinued. Does anyone know where I can purchase a set of new lower control arms with bushings and ball joint installed?
