Performance brake fluid...
I'm going to be installing Stainless Steel brake lines and want to buy performance brake fluid. What are the best brands and where can I buy them from? Thanks
I use ATE Superblue and Type 200 (superblue is blue, type 200 is gold so you can tell when you get fresh fluid when bleeding the brakes). They have a great wet boiling point (most important for street use), I think it is about 389 degrees and something over 500 degrees dry. It is about $10.00 a liter from www.ogracing.com or www.stranoparts.com and many others.
I think that Castrol SRF is one of the best out there. Great wet boiling temp {better than most's dry boiling temp plus it reportedly doesn't absorb water as bad as some other fluids. One problem though,,, it's high dollar stuff.
I've been useing Motul RBF 600. It has a dry boiling temp of 594 degrees and a wet temp of 421 degrees. The cost from my local motocycle dealership is 11 bucks per container {500ml/ 1 pint}, most likely can get it cheaper through mail order. The only drawback {desides cost} is that I've heard that it absorbs water pretty bad. I just run a bottle through it about every 6 months or so.
Castrol SRF = The best, crazy expensive
ATE Super Blue = Very very good, affordable
I personally run ATE super blue. I was considering SRF, but given the price tag I decided it wasn't worth it. You could buy yourself all the parts for making some brake ducts for what you save by going with the blue just once.
I agree that SRF is the best stuff out there, but the "bang for the buck" winner (my opinion) is the superblue. I've heard good things about the motul (and I've heard it absorbs water more than most but I have no personal experience to verify that), but for over 2 times the price of ATE, I'd try ATE first. I wont say it is "the best", but it is excellent stuff.
I was going through 5 or 6 1/2 litres of Motul brake fluid a year. It's rather humid and hot here, so the fluid contaminates very quickly.
I changed to SRF and went 18 months on nothing more than a sanity bleed.
Writing the check for $65/litre brake fluid is tough. But it pays for itself in the long run.
My results ... YVMV
My results ... YVMV
LS1TECH Sponsor
ATE is 536 dry, 392 wet. Exceeds DOT4 for it's ability to resist pulling in moisture. FWIW
__________________
Hey Sam,
Glad to see you back here. Please tell me that you finally gave up on LS1.com and decided to concentrate here and at LS2.com.
Side Note: I am really happy with my purchase of the Bilsteins from you. Arlyn and I must have talked for about an hour, about Penn State, and getting into SCCA Central Pennsylvania chapter. She even went so far as to give me the name and phone number of the guy that runs it.
Thank you again very much,
Tony (another satisfied StranoPerformance customer)
Originally Posted by mitchntx
Castrol SRF dry 590 and 518 wet. So, even fully saturated, it's almost as high as most dry. Install it and forget about it.
Originally Posted by rushman
Does the type of brake line dictate what fluid you should use or would I be good with SRF on stock lines?
Originally Posted by Carlos01SS
Where can I get the Castrol stuff?
Trackbird gave a link to 2 places in the second post of this thread.
Here is a direct link: http://www.ogracing.com/eshop/home.asp?categ=68
