Rear Sway bar install........GREASE or NO GREASE.......
Can this be put back on with weight on wheels....or do the tires and rear-end need to hang....?
I removed it with the wheels hanging with the car on jack stands......
I lost both brackets while driving because a mechanic did not tighten them back. So I have to install complete new brakets, all metal pieces.
Do I bolt the brackets and bushings to the rear-end first. Then the end links....?
Or the end links first....then the brackets onto the rear-end.
Do I install the rubber bushings dry.....or do they need a little grease...?
Factory bushings and brackets.......
****I ask because I see on some aftermarket brackets....they have grease fittings built in.......
Thanks....
Thanks....
