Wilwood Rear Brake Kit with Moser 12-bolt?
Does anyone know if the fixed calipers of the Wilwood (PN 140-9830-DR) rear brake kit with the Superlite 4-piston calipers will work on a c-clip elminator axle like the Moser 12-bolt?
I thought you couldn't run a c-clip rearend (like the stock 10-bolt) and fixed calipers, so I don't know how the Wilwood is setup if it works with the stock rearend and whether that configuration messes with something like the Moser?
Thanks!
Thanks!
From what I have been told, if you're going to run fixed calipers you need a c clip eliminator axle. You can reuse stock brakes with such an axle as well as the stock axle, so get the rear and then upgrade brakes later. You can run a fixed caliper with the stock 10 bolt but something about rotors sliding around and banging against the axle and causing you to **** yourself was mentioned, so I wouldn't do it.
As for the brake hats or shoes or whatever they're called, I want to know the same thing myself because I want to do big rear brakes eventually.
