Koni yellows settings for the rear getting wheel hop.
The car is a 02 WS6 with Strano springs Koni yellows with on car adjustable rears and strano sways. Doing a light burnout the rear starts hopping how can I try and help or fix this by adjusting the rear shocks down or up?
Changing rebound setting won't do anything for wheel hop. You need some LCA relocation brackets to change the angle of the LCA's. I had your exact setup and got bad wheelhop. Grabbed some LCA relo brackets and poly/rod LCA's from Founders Performance and no wheel hop since.
