Sticking brake caliper??
2000 camaro
R/f brake caliper sticking. I also have a line lock installed and 4ch abs unplugged but still on the car and routed. When I first discovered it was sticking I went ahead and put the right side rubber line and caliper assy. Also bleed the brakes. I also noticed when doing a burnout with line lock engaged it either doesn't fully engage the left or the right is so stuck that it actually just holds that side only. If I was in an empty lot I would be able to keep the r/f wheel planted and make a full circle.
Well it's still sticking,while in the air I have to turn really hard on the wheel to have it turn. Any ideas,could I have bad solenoid. I have not opened the bleeder screw yet. Could having the abs plugged and not working be causing this?
