F-body brake booster ratio?
Old 02-27-2016, 12:34 PM
JimMueller's Avatar
Default F-body brake booster ratio?
I looked through my Helms manual and I don't see any reference to the OEM brake booster ratio. Anyone know what it is?
Old 02-28-2016, 05:01 PM
1 FMF's Avatar
the booster working off engine vacuum I think is supposed to see at least 18" of vacuum. ballparking numbers call that 20" of vacuum. atmosphere is 30", so you're looking at 2/3 of atmospheric = 14.7 psi * 2/3 = around 10 psi of help.
I don't know the size/diameter of the booster, but pounds per square inch means if you got 10 psi of help from the atmosphere,
area = [pi * r^2] then
Code:
booster diameter        area         force
7"                       38"          380 lbs
8"                       50"          500 lbs
9"                       64"          640 lbs
10"                      79"          790 lbs
Old 02-28-2016, 05:33 PM
1 FMF's Avatar
http://www.classicperform.com/PDFs/B...ssureChart.pdf
Old 02-29-2016, 09:12 AM
JimMueller's Avatar
I found a manual way to measure it below, but I was hoping to just find the ratio documented somewhere.
http://brakepower.com/help_abc_16_BAR_t.htm
Old 03-13-2016, 12:59 PM
JimMueller's Avatar
Do you think this will get me in the ballpark?
Assuming vacuum=15, Baro=30, diameter=8 equals ~624lbs of force generated by the booster
If I already know the brake pedal output force is 255, then would the booster ratio be 625/255=2.5%?
Edit: Found this also:
https://grassrootsmotorsports.com/fo...r/18218/page1/
Old 05-11-2016, 08:59 AM
JimMueller's Avatar
In case anyone looks for it in the future. I bought this:
Amazon.com: SSBC A1704 Brake Pressure Gauge Kit: Automotive Amazon.com: SSBC A1704 Brake Pressure Gauge Kit: Automotive
The dial on the gauge was only 2", so we had to make a guess when the needle fell between the marks. Also, the gauge face is plastic, and exposure to the brake fluid caused portions of the face to become cloudy. An extension between the adapter and gauge along with a glass face would make things easier all around.
With 120lbs of brake pedal pressure and Wilwood brake proportioning valve set to full flow:
LF caliper: ~925psi
RF caliper: ~925psi
LR caliper: ~1125psi
RR caliper: ~1125psi
We measured multiple times. Going through the OEM 1998 F-body ABS block, the front ratio is ~8:1, the rear ratio is ~10:1.
Quick Reply: F-body brake booster ratio?
