Pulling to the right when braking
When braking the car pulls to the right. The pull is similar to an alignment pull the faster i go and harder i brake the harder the pull. I have also noticed when stopped on a hill and releasing the brake the R/F is the last brake to release its hard to explain but you can feel a slight delay in the release of that brake.
I have cleaned and lubed the slide pins on 2 different occasions. That seemed to help for 3-5 applications of the brake. This past Saturday I changed all 4 brake lines and did a brake flush. The issue is better, it doesn't pull as hard but the pull is still there.
I've searched and can't find any topics on this. I don't want to blindly throw parts at the car until I stumble on the issue. Any suggestions?
Vehicle info - 2000 Camaro SS 6 Speed - stock brake system - 81k miles.
You answered your own question, you have a RF caliper that is grabbing differently than the LF caliper thus making it pull when braking and why holding up after releasing your brakes. Possibly even dragging while moving.
Vehicle is 17 years old with 81k miles, it may be time to rebuild or replace that caliper or even an upgrade to a higher quality brake set up.
