HELP with ABS INOP and TCS
So when I installed my SLP radiator I accidentially knocked off the EBCM plug, so when I started the car ABS INOP and TCS indicators are on. I put the plug back in the EBCM, and disconnected the battery overnight but that only reset my PCM....not the darn EBCM.
Without a Tech 2 Scantool any one know how to re-set the system?
Measured all wheel sensor ohm's supposed to be 800-1600 ohm range.
fronts are 1100-1200 ohm range
rears are 3200 and 3300 ohms....doh..
I am going to buy two 1000 ohm resistors and plug them into the rear harnesses to see if this makes the EBCM happy...if it does then I'm going to buy two new rear wheel speed sensors!
FYI, to reset the ECU, have the key in the on position, pull the PCM BAT, and IGN fuses in the engine bay, let it sit for a minute. THen take the keys out. replace the fuses, then start her up.
Turns out that the ABS sys. just needed to self test by having the wheels move. I kept testing it in my garage on jack stands. I did not replace the wheel sensors, just hooked everything back up and as I left my neighborhood the lights went off and never came back on.....even stomped a 350Z for fun on the freeway!!
