shock/srtut/ spring combo
Old 07-26-2004, 04:27 PM
ninobrn99's Avatar
Question shock/srtut/ spring combo
what is a good set up for daily driver/drag racing? i cant afford qa1's or anything like that. so something in a resonable price range. is it even worth it to lower your car? would it be bad if i didnt lower but did relocation brackets, lca's and a Panhard bar?
Old 07-27-2004, 07:49 PM
SOM SS's Avatar
If you don't lower your car, don't use relocation brakets. It will screw up your suspension. LCA's and a PHR are a good idea. An inexpensive shock alternative to Hals is the Tolkico Adjustable shocks in the rear with non adjustables in the front or you can go with AGX adjustables front and rear.
Old 07-27-2004, 08:20 PM
ninobrn99's Avatar
would you be refering to the tokico illumina's? (i think thats what their called?) would the BMR springs, adj. lca's, relocation brackets and adj. PH bar, along with the tokico's be a good set up? would spohn be a good all around set up? how will it affect daily driving and cornering?
