how do i remove isolators?
Old 08-12-2004, 11:02 PM
heyitsTaJay's Avatar
Default how do i remove isolators?
i want to lower the car in the rear. how do i get the spring out so that i can remove the isolator on the top?
do i haveta drop the rear? any easy ways of doing this?
J
Old 08-13-2004, 12:34 AM
Cal
Cal's Avatar
No, you don't have to remove the rear from the car. The only thing you have to unhook is the shocks, and if you have short lowering springs sometimes you don't even have to do that. Just support the car so the rear axle can droop as low as possible, and unhook the shocks. You should be able to lift the springs right out at this point.
Old 08-13-2004, 12:37 AM
Ferocity02's Avatar
Like he said... Just unbolt the bottom of the shock to get the rear low enough. Then you can get the springs out. You will have to go to the store and get some heater hose to go on the spring so it doesnt rattle.
Old 08-13-2004, 12:42 AM
Cal
Cal's Avatar
Yeah don't forget the heater hose, 5/8" I believe.
Old 08-13-2004, 09:09 AM
unhook the shocks from the axle right?
how much heater hose do i need?
Old 08-13-2004, 07:04 PM
Ferocity02's Avatar
Right, I think it should work by unbolting the bottom of the shock.
You only need enough to cover the top coil that will be seated. I think 2 feet will be more than enough to do both, it's cheap stuff anyways.
Old 08-13-2004, 08:34 PM
thanx guys. i got the iolators off and love it. shoulda dun it earlier
J
Quick Reply: how do i remove isolators?
