OEM GM Pads / iRotors
i will be purchasing a set of cross drilled / slotted rotors from iRotors and using oem pads for minimal squeaking and dusting.
question is: where is the best place to find the cheapest oem gm pads?
also, are the iRotors going to have any negative effects on braking performace as opposed to using rotors from autozone?
Thanks, any help is appreciated!
I like my irotors
Some will say that slotted and drilled rotors are purley for bling bling and are no better than the autozone blanks. I really can't say since I've only had the stock rotors and now the iRotors. I think they stop great and the price is right. Also, you don't have to go with the OEM pads to get low dusting. I have Raybestos cermaic pads, and I'm very happy with them. Very little dusting and I think they are cheaper than the GM pads. If you need the GM pads, maybe check with the dealer or google it.
Good luck!
Bob
Good luck!
Bob
Originally Posted by DMNSPD
How about dealing with a little more dust while getting a lot better braking performance?
