Traction control unit & ABS??Need help!!!
Ok i both a KTRE 12 bolt rear end bare housing for my car.Now i'm buying the rest of the parts that i need to complete the set up like 33sl. posi,gears,axels etc.
NOW my question is i have to order a set of axels and my car is a 4 channel ABS and have traction control.If i delete the ring at the end of the housing i going to loose both the ABS and TC or just the traction control.The computer use the same sensor for ABS and TC?
I need help because i have to deside if i order my axels with the rigs or without them.Thanks in advance
