Need suspension advice....
I get my baby girl, 1998 WS6 Trans Am, back from the shop tomorrow, thanks Chris, in case you browse this forum too :-), and I need some advice. She has been a slow rebuild and I am down to the final components. I replaced her entire read end first, cause she had no axle after her crash. Now she needs front suspension. The parts to return her to stock will run around $700 (her control arms are bent). Should I take this opportunity to upgrade her suspension all the way around, or should I jsut stick with stock. I don't have a whole lot of money to burn so cost concious is important.
Originally Posted by New Era Performance
You might as well upgrade now , the cost should be close to the same unless you can find some used factory parts .
