Setting pinion angel-How to
Hey guys. My car has started to have a very bad vibration at speed. It happens mostly in 5th or 6th at speeds between 55-70. its the worst under light throttle loads.It does change with different throttle angles. I think my pinion angel is off. I have it up on the lift right now and put the magnetic angle finder on it. If i put it directly under the torque arm it reads +6. If i put right under the pinion it reads +10. Is t his the correct way to read it? or should it be on thr ground? And if it does need to be on the ground, how do you adjust it??
