DIFFRENCE between regular bilsteins/slp bilsteins/revalved bilsteins
DIFFRENCE between regular bilsteins/slp bilsteins/reval1ved bilsteins what goes best
what is the diffrence between the i have the pro kit and was deciding wich to buy
LS1TECH Sponsor
SLP's are revalved, but only one way and intended for certain springs. Also they use a regular 4th gen HD rear. I revalve mine based on what you have or do. Spring rates, swaybar, tires, street car, drag car, autox car, track car, or some combination all play into the valvings. I also run a couple of different rear shocks determined by the same parameters.
You don't tell me how you want them, as most folks know nothing about it. If you want to, I will do that but part of the service is working with you to figure out what you need.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
