Broken Shock
It looks like the nut is still there, the rubber mount just failed. Then, the shock beat the threads to "death". I'd replace the shock and the rubber mount and try again. If you are doing one, you may want to change both front shocks (and check the other mount).
Good luck!
Good luck!
Good luck!
Good luck!
