Do the GM 1LE rear control arms actually come with 1LE bushings?
I know that this might be a stupid question, but I found this list of 1LE part numbers:
See where I have the bold--there is a separate part number for just the 1LE bushings making me wonder if the 1LE bushings actually came with the 1LE rear control arms. Do the 1LE control arms actually come with 1LE bushings? Thanks in advance for the info.
1LE rear panhard bar (94-99) = 10262147
1LE left upper control arm (93) = 17999419
1LE right upper control arm (93) = 17999420
1LE left lower control arm (93) = 22145389
1LE right lower control arm (93) = 22145390
1LE left upper control arm (94-97) = 22145653
1LE right upper control arm (94-97) = 22145654
1LE left lower control arm (94-97) = 22156435
1LE right lower control arm (94-97) = 22156436
1LE left upper control arm (98-99) = 22156461
1LE right upper control arm (98-99) = 22156462
1LE left lower control arm (98-99) = 52367658
1LE right lower control arm (98-99) = 52367659
1LE front sway bar (32 mm) (93-99) = 26032907
1LE front sway bar bushing (32 mm) (93-99) = 26039956 (formerly 10288551)
1LE rear sway bar (21 mm) (93) = 10021221
1LE rear sway bar bushing (21 mm) (93) = 10235886
1LE rear lower control arm (93-99) = 10164151
1LE rear lower control arm bushings (93) = 10164152
1LE transmission mount (93-99) = 22146231
1LE front springs (LT1, 360 lbs/in) (94-97) = 22132561
1LE rear springs (LT1, 130-170 lbs/in) (94-97) = 22132562
1LE front springs (LS1, 360 lbs/in) (98-99) = 22132887
1LE rear springs (LS1, 130-170 lbs/in) (98-99) = 22132889
1LE front shock absorber (Decarbon) (93, early 94) = 22124758
1LE rear shock absorber (Decarbon) (93, early 94) = 22124790
1LE front shock absorber (Decarbon) (late 94, LJ build code) = 22140190
1LE rear shock absorber (Decarbon) (late 94, 4Z build code) = 22140187
1LE front shock absorber (Koni yellow) (96-99) = 22140240
1LE rear shock absorber (Koni yellow) (96-99) = 22140228
1LE rear shock insulator retainer (98-99) = 22166910
1LE rear shock lower insulator (98-99) = 10009135
1LE rear shock upper insulator (98-99) = 22166909
1LE endlinks = 10221779
1LE panhard bar = 10262147
