Anyone ever removed the back insulaters on coil springs
Old 02-15-2006, 09:02 AM
  #41
LuvMyZ's Avatar
Originally Posted by CompTA
With this mod, would an adjustable panhard rod and LCA relocation still be necessary for best results, or does it not change the geometry of the rear enough?
I also wonder this???
Old 02-16-2006, 08:21 AM
  #42
CompTA's Avatar
Anyone know?
Old 02-16-2006, 08:26 AM
  #43
weestro's Avatar
You are still lowering the car so the geometry of your LCAs will be thrown off. You will need brackets to bring the LCAs back to parallel. Adj PHB you might be able to get by without if the rear end stays centered. Measure to be sure.
Old 02-16-2006, 10:28 AM
  #44
LuvMyZ's Avatar
Thanks. That's what I figured too.
Old 02-22-2006, 11:14 PM
  #45
skewba98z28's Avatar
Doing the hose mod tommorow. My pro kit has about 25k miles on it and the rears are sagging. I'm going to put the stockers back on in the rear especially after seeing LuvMyZ's stance. I will post before and after pics.
Old 02-23-2006, 12:19 AM
  #46
tbird31's Avatar
i did the hose mod 2 weekends ago...sorry i haven't posted until now.
the back end of my car dropped about 1/2" to 3/4". So alittle more than i expected but it looks awesome!
Here's a picture.
Old 02-23-2006, 07:39 PM
  #47
Alright did the mod today. Went from a pro kit with about 25k miles on it. To prokit in the front and stockers on the rear with the hose mod. It made the car look so much better. It measured 26 1/2in before and almost 27 1/4 after at the top of the wheel wells. The car rides so much better now. I'll post before and after pics tommorow.
Old 02-23-2006, 10:38 PM
  #48
bangdiggity's Avatar
Default intrax
can you do the mod with intrax springs? my rear sits up prob a half inch higher than the front and it bugs me. ive only heard it done with stock springs, so i was just wondering. it sits level when i get my salt bags in the back for the winter i want that year round
Old 02-24-2006, 11:23 AM
  #49
Yeah you can do it on any spring. Your going to be low though. Especially on INTRAX Springs
Old 02-25-2006, 08:59 AM
  #50
LuvMyZ's Avatar
Post pics everyone! tbird31, looks great and perfect rake. Jim
Old 02-25-2006, 02:05 PM
  #51
weestro's Avatar
Here's mine with stock springs + heater hose and bilsteins.
Old 03-02-2006, 07:53 PM
  #52
jorgez28's Avatar
So the heater hose is placed there instead of the isolater?
How do you take the isolater off?
Old 03-03-2006, 04:58 AM
  #53
Foxxtron's Avatar
The isolater just rotates, or sometimes just pops off. It should be too difficult to remove the stock spring isolators.
Old 03-10-2006, 05:43 AM
  #54
minesfaster's Avatar
So i have bmr lca's if i do this mod will i need relocation brachets ? Also i hear that it lowers all cars different heights ?
Old 03-10-2006, 09:24 PM
  #55
Jaspirr's Avatar
Is there a write-up for this anywhere? Do I need a spring compressor or anything along those lines, or could it just be done with simple garage tools? I'm thinking about trying this. I have ramps, jacks, jackstands, all the usual tools, and a good amount of experience(did my own header install, and cam/spring install). I'm just not sure how to get to the point where I put the heater hose on. Thanks.
Old 03-10-2006, 10:27 PM
  #56
Foxxtron's Avatar
Here's a write up:
http://www.ls1howto.com/index.php?article=8
I highly doubt you'd have nay trouble with this. AFA the spring compressor, only the fronts are need them, not the rears. They simply fall to the ground once the rear jack stands are in place and the axle is carefully lowered.
EDIT: Bear in mind that the replacement they're using is something completely different than the heater hose/garden hose mod.
Old 03-10-2006, 10:31 PM
  #57
Foxxtron's Avatar
BTW, the heater hose completely replaces the rear isolator.
Old 03-11-2006, 09:56 AM
  #58
LuvMyZ's Avatar
When I did mine I had to loosen up the rear sway bar quite a bit. My springs would not come out until I did that.
Old 03-11-2006, 10:19 AM
  #59
weestro's Avatar
I used a pry bar to get the bottom coil off and on the perch on my 12 bolt. Even with the rear fully extended the springs still needed a bit of caoxing. No compressors tho...
Old 03-11-2006, 05:38 PM
  #60
is it fine to do this mod and not use relocation brachets if you have lower control arms ?
Quick Reply: Anyone ever removed the back insulaters on coil springs
