LCA Relocation bracket on stock ride height?
I have searched and come up with mixed info about LCA relocation brackets on stock ride height. From what I understand, the car will benefit so long as you don't experience brake hop. Is this correct?
The LCA Relocation bracket helps wheel hop - that is the reason why most people install the brackets. With the stock tires, I have bad wheel hop and will be installing the brackets this spring.
Bill
Bill
reply
thunder racing sells bmr brackets. i am going to order a set of bolt in's tonight because my car is lowered and my lca angles are off causeing it to spin more plus i have the stiffest springs they make [hypercoils] so it dont squat at all. i have read that the help so i gyess ill see.
