LCA brackets where I can pick my axle height
What solution(s) are available so I can pick the axle height with relocation brackets? What I'm concerned about is if the brackets are pre-drilled but the holes still put the axle too high or too low. I'm looking for something the functional equivalent of a slider or a vertical double-ended heim joint which can adjust the axle height instead of pre-drilld holes. I can drill more holes, but will be concerned about integrity of the bracket.
Oh, and this is not for a drag racing application
Jim....aren't you asking this on the wrong board???
If you were to do anything like that, I'd use a serrated mounting "slider" setup (think dirt track/oval track PHB setups). With the loads on that joint, I'm afraid it might not stay where you put it. I'd probably do as Rob and Jon did and drill the holes you need (you may need to weld on a doubler on the outside to give a place to put the holes).
Just my thoughts.
Just my thoughts.
Kevin... aren't you answering this on the wrong forum?
http://www.frrax.com/rrforum/index.php?showtopic=7136
Jason said for me to look in circle track catalogs for something like I'm requesting, but I haven't stumbled across it yet.
Hmm, I missed that one.....
I have an idea in my head, but I can't think of ever seeing exactly what I "need" for that application.
(I cross posted my first reply to see if it stirs up any conversation).
Let me do some looking and see if I find anything of interest.
