Cutting My Stock Springs?
I was thinking about cutting my stock coil springs to lower my car. Its an 02 Z/28 with LTs. Will my LTs hit the ground? Will I be able to get my floor jack underneath to change my oil? Has anyone done this? Is the ride quality **** afterwards? How much should I cut them? Thanks guys.
Measure the gap from the top of your tires to the wheel well (center). Go under car while it is lifted and the suspension is fully loaded. Measure the amount you want to lower for each spring from the bottom of the spring. Take the springs off and cut with cut-off wheel. Re-install and you're done with the springs. Don't forget about adjustable panhard rod to re-center the rear end and you'll probably need to adjust your pinion angle.
