LCA question
LCA question
i have my UMI LCA's in and my car was lowered when i bought it. and i think i need the relocation brackets from what the umi website said. what if i do not have relo brackets?
If you don't have wheel hop when you get on it, dont worry about..... they are meant to return the geometry of the LCAs back to normal after the car is lowered. If you look under your car you may see that the LCAs angle upwards going back to the tire from the frame, they are no longer parallel to the ground and that can cause wheel hop. The reloca brackets will level that out and make them parallel to the ground again
thanks man, i have not got my LCA's installed yet so i will just go ahead and get the relo brackets to be safe. im going to get my LCA's, TA , and SFC's installed all at once so maybe i can tell a difference.
