can I replace one rear scored rotor?
If one is scored chances are the other is/almost just as bad, but you can replace one rotor if thats what you are asking....i would find out why its scored and remedy that first though.
Oh well since brake pressure usually applies equal pressure to both rear and front brakes i would assume the other one is scored as well...but if not go ahead and replace the one rotor, you will be fine.
