Lt1 to ls1 brake question
Will ls1 rear calipers bolt up to a lt1 rear end? What all will need changed? just calipers and rotors? Any advantage of having rear ls1 brakes?
There is really no advantage to doing it. Most of the braking is in the front anyway. If you change out the front then you are OK. The rear require different parking brake cables and is a pain to change out for little benifit. I'm not sure about the backing plate being different or not.
