Brake fluid question?
Moderator
I just changed my brakes to Slotted/Cross Drilled Rotors & Hawk HPS pads. I want to use DOT 4 fluid. Can I just suck out the resivor with a turkey baster and refill it?
I don't want to drain the system and refill/Bleed.
Copy & Paste Moderator
I might try that. I'll have to read the lable on the can to see if it is compatable with DOT 3 just to be safe.
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
(Its also in the Brake FAQ)
