Eibach drag springs
Here is a pic with the drag launch springs before I put in the 12 bolt. That is a 275 50 15 rear tire on a 15 x 10 rim with 5.5 BS.
Here is the same wheel with a 275 60 15 tire. The drag launch springs are still on the car but I have done the hose mod to lower it down a little bit.
I have also installed the Strange 12 bolt that has been shortened 2.5 inches on each side.
I have no problems with these springs. I will have to change the front springs when I go to QA1s but only because I want to take advantage of the matched spring.
Handling is fine if you keep in mind they are DRAG springs and are not meant for handling. I have no power steering and run on skinnies at all times. I don't take corners fast at all.
