rotors/pads
rotors/pads
like to get some new ones my stock front rotor cracked...so id like to get brembo blanks and hps pads...cant find brembo blanks anywhere...anyone?
o really's said they have a part number and its listed but they cant get or order them
if not o really's has wagner blanks for 69? and regular house brand for 29...any differance?
sunset, you have no clue. squealing has nothing to do with the rotors. For the most part all you want from a rotor is one that will not crack or warp. Autozone's, although made in china, are better than stock and almost as good as Brembo's (when they were made in usa).
Squeal is caused by pad material, shims, seized guide pins, worn or missing spring clips...or a combinations of such. Did you try using ebc red anti-squeal junk?
Tire Rack also stocks Brembo blanks for our cars. But I would rather buy them (for about the same price anyway) from Sam (Stranoparts). He gives priceless info/help/suggestions, forgot more about these cars than anyone at TR will EVER know about them (they are mostly BMW/import fanboys over there), and has tried/driven just about every combo possible as far as brakes and suspension on 4th gen f bodies goes.
i used to have a full set of stock rotors that were unwarped and had 30 miles on it from a guy who took them off his SS to go with a different setup. im gonna see if i have them in the closet or if i threw them out when i moved and if you are interested ill give em to you daniel. im goin to take pics of those tires this evenin too by the way. -Karl
The Brembo blanks probably have the best metallurgy and venting of any of the OEM replacements, and therefore are the least prone to warping. But I've heard the AZ Duralasts are not too far behind them in quality. Either way, they are BOTH better than stock, or any of the cheaper Asian made rotors.
Originally Posted by daniel6718
im goana do hawk hps pads either way but is it better to get some autozone blanks? (the cheaper ones or duralast) or some brembo blanks? im tired of warpage and dont wanna have it again!
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Copy & Paste Moderator
anyone else on the brembo blanks?
also there was a thread that some1 said something about badass fluid and had a link to the same site as above. anyone know it?
http://www.stoptech.com/tech_info/te...e_papers.shtml
In there is a link to this page on Brake Fluid:
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
