Tweaked ES trans mount. How do I keep from happening again? *Pic*
Hey, put the energy suspensions poly mount in my car several months ago. I ran the plate for a week, then took the plate out due to suggestions on the board. It was a ton smoother.
Lately I've been having a weird clunk back and forth and vibration issues. I crawled underneath and checked the mount and saw this.
Now you can see the problem.
I'm on my way to buy another one right now. Any tips how to keep this from happening again? I torqued down everything to spec with loktite, but didn't re-tighten later. Could that have been it?
OK, well until someone can help me out with the above, I have another question. What'd you all torque the single bolt that goes into the trans mount. Not the ones that hold the bracket in place, the one that goes in the center. There isn't any specs with the mount or in my book. I think I just torqued the hell out of the past one, so maybe that's what did it. This time I went till it was really snug, but not until stop. Loktite of course.
I had the exact same thing happen to mine First time was without the preload plate in there.. current mount I left the preload plate in and shimmed the crossmember down and it still did it but not as bad. I have Poly motor mounts too so its not like the engine is moving around a ton. I've ordered up a Prothane mount instead. hopefully it will work.
If it happens again I'll go with the Prothane one.
