rear spring isolators
i cheat by placing the isolator on the spring first,it has a notch where it is to be seated.i use a small piece of electrical tape to hold the isolator on the spring and install
you can also ditch the isolators and use 5/8 heater hose on the coil and instal it that way,it will give you a 3/4-1" drop in the rear with no adverse affects.
