List c5 swap parts and stories!!!
We should have a list of all and every part that is required to perform the c5 brake up-grade. (LS1) We all know about calipers, pads and rotors. waht about brake hoses, washers, caliper pins and brackets. This would be some great info.
If we can post the part numbers and sources/prices it would be even better.
i got the kore 3 kit on my car (LT1). i used everything that came with the kit.
i did price out what all was needed if i decided to buy everything individually.
here is the GM parts number list from another site. that's everything minus pads and rotors
GM Parts List for 93-02 F-body to C5 Front Brake Conversion
GM Part # Quantity Description
12530682 1 Right front caliper (standard C5)
12530683 1 Left front caliper (standard C5)
10445856 1 Right front rotor
10445857 1 Left front rotor
12455799 2 Pad abutment bracket
22163727 2 Front caliper brake hose
12530697 4 Pad abutment guide pin
12530703 4 Guide pin boot
22163795 2 Banjo bolt
10139097 4 Banjo bolt copper washers
GM parts list notes:
• If you want the red Z06 calipers, use Part #s 88895128 and 88895129 in place of caliper #s above. The cost is usually the same.
• The guide pin bolts come with the calipers, so the part number is not listed above.
• The C5 calipers come fully assembled.
NOTE: I did not come up with this list. it is from fullthrottlespeed.com (formerly speedspecialty.com) don't know if they're a sponsor, but i copied/pasted it from their site so i felt i needed to give credit to them for this list.
