c6 z51 rotor
c6 z51 rotor
i would like to upgrade my c5 z06 brakes to use the larger z51 13.4" rotor...
got the PAB 88964166 x2... but it seems GM still only has the one rotor and still running the other side backwards....89060328...... so where can i get a set off one piece rotors with side-sensitive vaning?.... ill take one GM and one correct aftermarket for the other side....two piece is a bit to much for the budget as the autox eats these things up...
