control arms
control arms
i boxed my factory control arms and put in energy suspension bushings. to try and keep the stock look underneath and save money. i saw next to no difference on my street tires. it took away alot of the wheelhop but now it just spins bad.i might throw my slicks on tommorow to try it. also when i shift the car there is a loud clunk from both the back of the car and under my seat i think its the torque arm. that will me my next step.
For the clunking check your control arm bolts, when you took them out to box them you may not have tightened them enough.
For spinning a torque arm is a great start. Also a inexpensive start would be a set of control arm relocation brackets. Check out the links below and if you have any questions please ask.
www.umiperformance.com/2010
www.umiperformance.com/2012
Thank you!
Ryan
Thank you!
Ryan
