WILWOOD brakes
Old 11-08-2007, 12:05 AM
chrismorales75's Avatar
Default WILWOOD brakes
I was wondering if swapping the calipers side to side so the caliper mounts in the front would effect braking on the rear brakes.
Old 11-08-2007, 12:40 AM
chicane's Avatar
It wont change a thing... as long as you have square bore four piston calipers. If they are stagger bore calipers... it will most likely lead to a pad taper issue.
Old 11-08-2007, 10:52 AM
No they are the 4 bore calipers, the pro street vented rotor kit. Just trying to make some more room from my panhard bracket since I am getting my rear end narrowed.
