lower control arm bushings
Old 11-26-2007, 09:16 AM
sj24's Avatar
Default lower control arm bushings
Does anyone an aftermarket part number for a full rubber bushing on the front lower control arm where the bushing goes in vertically?
Old 11-26-2007, 10:53 AM
leadfoot4's Avatar
Moog sells a set of both bushings, and it's p/n K6490. TRW sells the vertical bushing separately as p/n 12650.
Old 11-26-2007, 11:58 AM
sj24's Avatar
Thanks!
Old 11-26-2007, 01:59 PM
sj24's Avatar
The K6490 Moog bushings that i got don't have the full round rubber bushings.
Old 11-26-2007, 03:43 PM
Greggy's Avatar
Nobody makes the full rubber caster bushing. They all have spaces. Only the 1LE bushing was solid rubber and the only way to get it is to order the correct number front LCA from GM with the bushings pre-installed. They do not sell them seperate.
