brake won't even hold my car stalling to 1,800rpm???
I'm thinking my calipers are going bad? I don't know I bleed them new pads and they still suck ***.. They also go to the floor.. anybody know the problem
there not all the way to the fllor but there pretty close. I'm thinking the calipers are letting loose after they clamp. Sometimes when I'm pushing the brake barely moving the pedal will pulse and the brakes will fade a lot? Idk kinda weird I can't stage good to race until i fix this.
when u first press the brake pedal and goes to far down pump it a couple of times, if pedal stop sooner then prior pump thats a sign of air in system. however if it goes down to the same spot I would look at master cylinder.
