New struts no there's a funny noise...
So i decided to change my front shocks on this fine christmas afternoon, and now after the install there is a relatively loud clunking noise that can be felt through the floor boards whenever i hit bumps. Has this ever happened to anyone else?
Did i forget to tighten something enough? It can be felt on the passenger and driver side.
thanks
thanks
where did you put the washer, and did you tighten the nut all the way? i put the washer in the wrong spot once and made a clunking noise on every bump. i suggest taking it out and apart and checking that, and tighten it down all the way
thanks for the replies...im pretty sure i didn't tighten down the nut all the way. But what washer are you spaking of? Im not sure i remember any washers...yikes
^I tightened the nut as far as it would go, put it back together. And it still makes the noise but its not nearly as loud. Like if i had the radio on you wouldn't be able to hear it....I prolly didn't help that i cut a coil off when i first did the swap.
add some washers...i seen the same problem with drop coil overs for a corolla. thats what the guy at the alignment shop did. it stopped the noise. i dunno where he put them though.
