which suspension package for moser 9"?
I will soon be ordering my Moser 9" and want to upgrade all of my suspension at the same time. I have read quite a few horror stories from people installing torque arm with aftermarket rears. I need frame connectors, torque arm, panhard, saftey loop etc. What does everyone recomend? Thanks for the advice on a big decision!
Im pretty sure the new moser 9" can come with their own torque arm. If you dont get the torque arm I would check out BMR. Click packages, then check out drag packes. One for the street and on for strip.
LS1Tech Premium Sponsor
gotcha covered... the best rearend, the best suspension parts, and the best prices. if you are gonna do it all, then the new fabricated 9 inch i have is by far the best deal out there.... quality and price.
my rearends feature built in 4 hole relocators, anti-sway bar brackets, and a drain plug, all at no extra cost. the driveshaft loop is included on the tunnel mounted torque arm setups, at no extra charge. 3 and 4 channel abs available, also.
the panhard, lca's and torque arm are all chromemoly, double adjustable, and use teflon-lined aircraft grade heims. all parts powdercoated.
you can get a housing, axles, complete center with posi and choice of gear, torque arm and crossmember, panhard, lca's, and subframe connectors for 3000.00 shipped to you.
theres alot of options on these rearends. pm me or call for quote.
