c5 brake bracket for f-body
Hello,
We can help with that- www.umiperformance.com/2120
In stock and ready to ship
If you have any questions please e-mail us at sales@umiperformance.com or call our technical support line at 814-857-5400
Thank you!
Ryan
Thank you!
Ryan
can you use your bracket to have c5 rotors but still use my stock calipers?
and to anyone else... what about these from lgmotorsports (in the faq) ...where do i get them?
Hello,
Thank you!
Ryan
Thank you!
Ryan
... LG Motorsport!
When I ordered them a few years ago, they didn't have them on their web-site. Pick up the phone or send an e-Mail-request.
With the LG brackets you can keep your F-Body brake-components, but you have to use the longer C5 brake hoses, because the caliper is being moved down in another position. That different look is something I don't like about the LG-brackets (having the calipers moved downwards).
Also, with the F-Body calipers on the C5-rotors, the brake bias is moved to the front. I think it is okay, because I always felt that the rear axle was "overbraking", but you should know it.
Holger
bmr sells the cheapest brackets
http://www.bmrfabrication.com/F-bodyBrakes.htm
150 vs UMI 240
I am not sure though if the bmr will support fbody calipers, but with either the bmr or umi you have to cut the stock spindles
lg motorsports are designed to not have to cut the spindles, and support fbody and corvette calipers, but cost 295
here's the link
brackets
remove everything from the package but the brackets (select none for rotors)
150 vs UMI 240
here's the link
brackets
