ok i wanna get a sway bar and torque arm, help me out
im lookin at getting the slp 21 mm rear sway bar. should i or should i not? i found it for 69 bucks. and torque arms, where is the best place to get one from? right now i have the bmr in mind for 320. anywhere cheaper or anything better than the bmr? thanks guys
Re: ok i wanna get a sway bar and torque arm, help me out
I went with BMR sway bars and I think they work great, as for a torqe arm I'll be going with the Eldebrock torque arm. A friend of mine has one on his SS and he loves it, it's a non-adjustable arm and cost about $180 from Jeg's.
Al
Al
any problems with it being non adjustable? or does it set the right pinion angle or whatever. im not too sure on why im changing it besides it might be stiffer and the changes the angle, i was told i need to get one though lol so someone fill me in please, thanks
The non adjustable is just fine it will keep your pinion at the right angle and it's stiffer than stock and lighter. You only need the adjustable if you do alot of 1/4 mile runs at different tracks so you can set the pinion angle for the best bite for different temps and track surface, for the street and the once in a while 1/4 mile runs the non adjustable will work just fine.
Before u spend that dough, just a suggestion. Change the stock rubber TA bushing with a polyurethrane or a polygraphite. I did the first one and I'm much happier with traction. Oh by the way, I also did the same to my stock sway bar and both mod together kicked ***. All for a mere $64.
yeah i have the poly on the sway bars and tranny. its just that stock torque arms looks crapy and well the one from edlebrock looks good and its only 160 bucks so tahts cool. yeah those bushings made a world of difference though
I got BMR front and rear sway bars, LIKE'em a lot,not much body roll now, feels a lot better in corners, plus u can get them in the color of your car..to me, thats badass...
