pinion angle
pinion angle
what should the pinion angle be set at for "street racing" with a 12-bolt, bmr adjustable trq arm and a th400.
does hp have anything to do with it?
ive heard anywhere from -1 to -4
and how do i set it?
The question is...minus 2 degrees relative to what?
The answer is minus 2 degrees relative to your crank/transmission centerline. Here's what you do. Measure the angle at the face of the crank pulley (or at the rear of the transmission). Set the angle of your pinion yoke to make it the same as the first angle you measured. That makes your pinion angle 0 and means the pinion angle is parallel to the crank/trans centerlines--which is where you have the least drive train loss. To compensate for deflection under load, you adjust your pinion downward from there--usually 1-2 degrees for street applications.
