Changing the SPRINGS...
Finally changing the springs on my 94Z.
It is the Eibach pro kit 1.5 drop.
Just wondering if someone has any TIPS for me, to make this as painless as possible.
Thanks for any help...
use a lot of penetrating fluid on the upper shock mounting bolts. I got frusterated and rounded mine off and ended up having to buy new shocks earlier than I planned.
Here you go ----> http://www.ls1howto.com/index.php?article=6
Once you remove the torx bolts from the drivers side, install them on the pass side when you hook everything back up.
